Larini de-cat and sport centre te koop 3200 GT
Alleen Maserati-onderdelen! (zie forumregels)
Berichtdoor Dutchy » ma 05 sep 2011, 11:04
Daar gaan ze dan want ik doe er niets meer mee....
RVS De-cat pipes
RVS Sports center piece
Het zijn 3 losse onderdelen en zien er gewoon nieuw uit. Hebben maar heel even onder de auto gezeten en het is allemaal pasklaar. Wil je net een iets sportiever geluid en wat meer free flow. Kies dan voor deze opties... nanderhand met een Larini of Tubi einddempers heb je helemaal een prachtig geluid.
Set gaat weg voor € 750,-
Term sla je slag!!
Maserati 3200 GT, Larini 'Sports'Centre Section:
The 1 piecefactory cat section is a lengthy component that connects between the turbos andthe rear link pipes. This factory component incorporates 4 catalysts: a set of primarycatalysts, one bolted to each turbo, and a pair of secondary catalysts mountedside by side, wrapped in a silencer casing, housed under the front seats area.While these catalysts are a cost effective way of securing an emissions pass inall countries for the 3200 they are massively restrictive.
The Maserati 3200’s Twin Turbo V8 engine produces quiteunusual acoustic wave characteristics. If one replaces the factory cat sectioncompletely with a pipe-only de-cat assembly, the 3200 will sound horrendouslybassy; louder than even a Chevy V8 – not the desired sound for a Maserati3200 GT. After months of development Larini Systems has designed a highperformance Cat replacement section which incorporates a free-flow resonator todial out excessive sound frequency. Instead the Larini Sports Centre Sectionoffers a truly epic Italian sound while offering noticeable power gains.
The Larini‘Sports’ Centre Section replaces the original secondary catalysts.Once fitted, low speed driveability is dramatically improved. TheLarini Sports Centre Section reduces backpressure so as to make the powerdelivery of the car more linear, by aiding smoother turbo-spool-up. This makesthe car significantly easier to drive at low rpm and reduces excessive throttlesensitivity whilst actually boosting power at high rpm. The 'Sports' Centre Section offers one of the most economical meansof releasing power from the 3200 GT's engine: -
- A Stainless Steel ‘Sports’ centresection, which mates up to either the Larini ‘Sports’ Cats or‘De-Cat’ Pipes.
- Engineered for greater flow efficiency, usingexpertly engineered performance internals.
- Offers better quality sound across the rev range.
- Offers improved low/mid-range Torque.
- Offers much sharper throttle response.
- Delivers an extra 8 bhp. approximately.
- Engineered for optimal flow efficiencyby using increased diameter pipe work, and a free-flowingmid-resonator box.
This is incorporated to avoid excessive drone, bass or boomon the 3200 GT.
- Perfectly practical for everyday use.
- Does not vibrate or produce excessive volume atidle or cruising speeds.
- Constructed using aircraft grade T.304 AusteniticStainless Steel.
- Fully 'Mirror' polished for improved aesthetics.
- Features Mandrel bent pipe-work allowing aconstant internal diameter, maintaining smooth, constant gas flow.
- Precision engineered for accurate fit.
- Require no special procedures to fit.
- 100% Tig welding construction.
- Precision, laser cut, stainless steel mountingflange and brackets, for easy fit and removal.
- Supported by the Larini Systems LifetimeWarranty.
Please note: The Larini ‘Sports’ Centre Section mustbe fitted with either the Larini ‘Sports’ Cats or‘De-Cat’ Pipes.
Maserati3200,Larini 'De-Cat'Pipes:
** These replace the massively restrictive primary catalyticconverters, with 'straight-through' pipework.
Stainless Steel Catalyst replacement pipes, replacing the factory primary catalysts, which mate up to the Larini ‘Sports’ Centre Section.
Deliver an extra 19 bhp.
Deliver an extra 50 lb-ft of torque.
Vastly freer flowing in comparison to the standard catalytic converters.
Accelerated gas-flow reduces engine bay temperatures, protecting the turbos from damage, while optimising performance.
Pipework and bosses and are fully 'Mirror Finish' Polished.
Mandrel bent pipe work allows a constant internal diameter, maintaining a smooth, constant gas flow.
Constructed using aircraft grade T.316 Austenitic Stainless Steel.
Correctly positioned, heat-distortion resistant, CNC-machined stainless steel Lambda bosses and heat probe connections.
Requires no special procedures to fit.
Supported by the Larini Systems Lifetime Warranty.
Larini ‘De-Cat’Pipes are high temperature resistant, hollow pipes, which replace the 3200'sprimary catalytic converters. Exhaust flow is completely unobstructed throughthese 'straight-through' components and as result there is an extremelynoticeable power gain. Temperatures are reduced, as acceleratedgas-flow minimizes engine-bay temperatures by dissipating heat moreeffectively. This is particularly important for improved performance, as coolertemperatures boost engine efficiency while protecting the turbos from prematurefailure. Turbo performance is notably aided, once coupled with the Larinide-cat turbo down pipe.
Furthermore, the muffling effect provided by the bulky stock catsis eliminated, significantly enhancing volume levels. A 3200GT equipped withLarini ‘Sports’ Rear Boxes, ‘Sports’ Centre Section and‘De-Cat’ Pipes will offer a truly staggering acoustic opera withsimply shattering performance. Under acceleration the car simply hankers downunder throttle load and accelerated endlessly. While 'De-Cat'Pipes offer one of the most economical means of releasing power from theMaserati 3200, there are technical and legal implications to be considered.
Re: Larini de-cat and sport centre te koop 3200 GT
Berichtdoor Vince » ma 05 sep 2011, 11:25
Misschien handig om bij te zetten wat de nieuwprijs was?
Berichtdoor Dutchy » ma 05 sep 2011, 11:31
Als je het nu besteld betaald je er € 1.100,- euro voor.
Toen ik hem kocht was de koers anders en heb er € 1.240,- voor betaald.
Op de hagelnieuwe set is dat dus een mooie korting.... }{}{|
Berichtdoor maserati1 » zo 22 jan 2012, 14:59
Misschien een wat late reactie maar heb je deze set nog liggen?
Maserati 3200GTA 2001
Abarth 500C
Porsche 911 997 Black edition
maserati1
Geregistreerd: za 14 jan 2012, 17:27
Berichtdoor Dutchy » zo 22 jan 2012, 15:31
Ja heb ik nog... wat wil je weten?
Berichtdoor maserati1 » zo 22 jan 2012, 15:35
Zou graag een net wat diepere sound willen hebben bij mijn 3200. kan ik dan uit de voeten met deze set?
Abarth 500C
maserati1
Berichtdoor Dutchy » zo 22 jan 2012, 23:21
Een wat diepere sound zeg je.... die bereik je vooral met het wisselen van je einddempers. De zaken die ik aanbied worden meestal in combo gedaan MET de einddempers. Ik ben alleen nooit toegekomen aan de einddempers. Doe een leuk bod en ze zijn van jou.
Berichtdoor maserati1 » di 31 jan 2012, 20:49
Dutchy,
Ben nu op zoek naar einddempers om mee te beginnen. Ik laat het je nog even weten!
Abarth 500C
maserati1
Berichtdoor Danny » di 21 apr 2015, 22:19
Waar is deze set eigenlijk ooit gebleven? Term, heb jij die overgenomen?
Berichtdoor Term54 » wo 22 apr 2015, 10:35
nope , ik heb franco iets moois er onder laten zetten :-)
Keer terug naar Maserati-onderdelen
